Pro-Tools Pro RT - Screen Size
dwcy
Oct 2004
Hong Kong
22
Dear All,
I use ProTools RT in a computer. I selected OP270 as the virtual panel. However, when I run the RT file. The screen is exceptlly as the OP270 screen size. Can I maximize the window?
Hi dwcy.
Is your target an OP270 or is it a PC ?
If your target is a PC, then you can use the convert function to change the OP270 to a PC. When you do that you can select a screen resolution, 640x400, 800x600, 1024x768 or 1200x800.
hi
are u usin protool or protool pro ?
i think changing the display type is available only for wincc flexible not protool
He must be using Protool Pro. I dont think the simulation module is included in the satndard version.
Protool has the ability to convert between target types.
Look under File ... Convert.
Amr Hassan said:
hi JesperThanks , any way the simulation is available in the standard version also
Aha, they must have added it at some time. I used to have a standard version where there was no simulation. Later I upgraded to Pro and got the simulation included.
I have ordered a control technique undrive sp unit that will have a ez motion module in it and also a ethernet module that was suggested to me to...
3,404
Hi. Can someone please tell me what the differences are between WinCC Flexable, WinCC 6.2 and Pro Tools? Thanks
2,595
Hello all, I am currently facing a problem with a Pro-Face HMI PS5000 project file download. I have tried using GP-ProEX SP1 (4.09.350) and...
41
hello, I'm a student and for my final grade I have to repare a sepro robot. the only problem I have for now is that i have an error code 3...
50
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
145
