Problem conect PLC FX1N-40MT .
phuc0072000
Nov 2020
Ha Noi
Hj everybody , I'm a newbie
I have problem connecting to read the program from the FX1N PLC as shown below.
I use cable USB SC9 , and tested with cable Usb to Com , but both can't conect . I chose the correct COM port , and test connection successful .
I have tried this cable with another device, it can connect.
I use software GX Developer , and GX work 2 .
PLC no have password .
My computer use Win 10 OS 64Bit
If you have experience with this issue, please help me,
thank you very much.!
https://photos.app.goo.gl/wh95Y9riGHKyWGFv9
https://photos.app.goo.gl/oBgwf1BVHbmVZFhJ8
The LEDs, "Power", "ERROR" and "RUN" are not shining, but I/O LEDs are ON so I would say you have PLC malfunctioned. Also, hudging by the color of SC09 it is not original cable. However, I would try to download drivers from MyMitsubishi.
Ronnie, Should not matter as the FX Defaults to 9600 after power up, Both GXDev, Works & Beijers test at this then sends commands to adjust to the selected baud rate, found this out when I talked to Kepware regarding a problem after power up of PLC defaulted to 9600 but GX versions & Beijers would always connect even at 57k. But then again the interface cable does look like a clone & it may depend on the USB to 232 converter being good quality.
The only other time I have had this is wrong parity, stop bits etc. never on baud rate.
All I can say is I've had the same fault and it was making a connection but faulted on upload.
I changed baud and all was well.
Can't harm to try :)
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
53
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
75
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
78
23
586
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
72
