Problem in Trend
DEEBAN T
Jul 2012
Tamilnadu
25
hi all, I'm facing a problem in trends of my factory talk view SE.. Its showing the actual value in trend but its not trending(charting) that value in chart... need the help... what may be the reason for that?
problem in trend
sorry guys... the problem was identified on that day itself.. someone has changed the X axis value in years... but i'm facing one more problem... when i'm opening the trend its charting, it disappears when I change the screen. when I come back it starts once again... Simply trend is not working poll historical server..
You need a data log and then you need to make sure the pen references the data log. This will allow the history of the trend to show. The only draw back is you have to go to the trend for it to start, doesn't auto start and I haven't seen a start up script (if you have a lot of trends) to do that for you.
everything is defined and ok. what abt pen source? live data or data log? If I select datalog i'm not getting the value of the tag...
Hi guys, I'm new here and I just started to work as junior automation engineer. It will be much more easier now I have access to this site. Wish...
1,516
Hi,everyone! First of all,sorry for my bad english. Secodly, I'm just starting to work with PLC and RSVIEW32. So, i have a problem with trend. It...
2,169
Recently we lost our recorded data from all our popup trend screens. The values are still shown just not the pen lines. Any help would be greatly...
2,403
Hi I am using factory talk view SE 8, server and client, and i am using factory talk historian for trending. the trend working well on the server...
2,584
I'm having some troubles with Intouch trends, some trends are showing constant, the tag is updating fine, the trend of the others tags of the...
1,621
