Problem to understand Stl code
Berra
Mar 2007
Sweden
137
Hi
I have problem to understand this code?
can anyone explain this code for me?
L B#16#3
L #OBJ_NR
SLW
LAR1
L #OBJ_NR
L 4
*I
T #OBJ_NR4
L B#16#3
TAK
SLW
T MD 3000
AN #DS
A #TID_UTLOPT
S #LARM_DS
OPN "Objekt - Kvittens"
A DBX [AR1,P#0.1]
R #LARM_DS
R DBX [AR1,P#0.1]
A #LARM_DS
AN DBX [AR1,P#0.1]
= #OKVITT_LARM
Here's the code with comments added. If you need any more specifics, then please ask.
L B#16#3 //accu1=3 accu2=don't care
L #OBJ_NR //accu1=OBJ_NR, accu2=3
SLW //accu1=(OBJ_NR * 8) or OBJ_NR shifted left 3 bits
LAR1 //AR1 = (OBJ_NR * 8)
//The implication here is that each object has associated with it
// 1 byte (8 bits) of information. The address register now
// points to the base of the 8 bits associated with the
// particular object.
L #OBJ_NR
L 4
*I
T #OBJ_NR4 //OBJ_NR4 = OBJ_NR * 4
L B#16#3 //accu1=3 accu2=OBJ_NR4
TAK //accu1=OBJ_NR4 accu2=3
SLW //accu1=(OBJ_NR4 * 8) or (OBJ_NR * 32)
T MD 3000 //used for debugging ? anyones guess
AN #DS
A #TID_UTLOPT
S #LARM_DS
A DBX [AR1,P#0.1] //This tests bit 1 of byte OBJ_NR in the DB
R #LARM_DS
R DBX [AR1,P#0.1] //This resets bit 1 of byte OBJ_NR if RLO=1
A #LARM_DS
AN DBX [AR1,P#0.1] //This tests bit 1 of byte OBJ_NR in the DB
= #OKVITT_LARM
I have a problem trying to track bottles that come down two conveyors in series and are running at different speeds. Also inline, there is a...
1,521
Hi, I am newly joined member working as an electronic engineer in a process plant. I have a problem in a m/c equipped with Mitsubishi PLC...
32
20,285
Hey all, i was making edits to a program the other day and i had a Timer with two conditions set to it, but only one of the conditions would start...
3,237
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
23
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
39
