Problem with RsiOPCAuto
yang1216
Jun 2009
BeiJing
84
Hi all.
I am creating a dotnet application with RsiOPCAuto.dll, and I have managed to read and write tags value. But today when I wanted to display all the online tags in a treeview, I met a problem.
Following is my code.
Code:
            List<string> lstItems = new List<string>();
            try
                OPCBrowser browser = myServer.CreateBrowser();
                browser.ShowBranches();
                browser.ShowLeafs(true);
                var i = browser.GetEnumerator();
                if (browser.Organization == 1)
                    while (i.MoveNext())
                        lstItems.Add(i.Current.ToString());
            catch (Exception err)
                throw err;
When it executed "browser.ShowLeafs(true);", an exeption "[HRESULT:0x80010105 (RPC_E_SERVERFAULT)]" was thrown.
Has anyone meet the same problem also?
Please help me, thanks in advance.
Hello,
Are you sure you can read the leafs directly for the root as you are doing. I think that you have to select a branch (by MoveDown or Moveto) before using ShowLeafs
Hello,
Thanks very much.
I don't know what the branch means, is it group?
If I want to get all the item in the server, what should I do? Enumerate all the branches and then enumerate their leafs?
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
113
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
56
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
84
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
82
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
23
631
