Problem with Siemens CP5512 PCMCIA Card
cyber
Oct 2007
Oio
Hi.
Looks like my CP5512 is broken.
How can check if CP5512 is damaged or not?
MORE INFO:
My CP5512 doesn't work (Step 5.4 SP1). Cable (RS232 - DB9 pins 3,5,8) adapter is fine, driver is OK (driver instalation was OK). When I'm checking connection there is an error but when I'm checking CP5512 hardware there is a message - no hardware problems - IRQ19 and everything looks fine (no windows conflicts). I tried to connect to other CPU314, CPU317 - no accessible nodes at all = NO COMMUNICATION.
Any ideas, software links?
Respect,
cyber
Ciao guys, I'm not used to program on Siemens PLCs, but sometimes I have to. I'm experiencing a strange problem when I try to connect to a PLC...
3,997
Hi, Im working on adding multilanguage to my project. When using a button to change language I get "invalid value 0 in parameter xxx". The zero...
1,035
Good morning Please i need an advise, I have a s5 135u cpu system , it is installed on printing machine. Nowadays its stop about 10 times in 8...
27
4,323
Hello, I have connected ethernet cable with my laptop and the s120 control unit. setup my laptop ip 169.254.11.1 and subnet mast 255.255.0.0 ...
20
5,671
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,902
