Problem with Siemens OP27
VVM
Jul 2007
Russia
We have a problem in a system based on S7-400 and OP27. Occasionally, sometimes rather often, OP27 displays a white screen with a message “Anstehende SM” (“Waiting SM” (?)). It seems that S7-400 writes corresponding messages “Synchronization between Master and Slave is lost” (or something like that) into its diagnostic buffer at these moments.
The same screens with “Anstehende SM” I see when I test the disconnected panel offline (on a table, without PLC, and also occasionally).
I couldn’t connect to OP with ProTool (in fact, I have absolutely the same case), despite I could connect to it with ProSave and to make backup without any problem.
I cannot understand: is “Anstehende SM” either the OP’s system message, or the user-programmed message, and what do they mean?
Ciao guys, I'm not used to program on Siemens PLCs, but sometimes I have to. I'm experiencing a strange problem when I try to connect to a PLC...
3,911
Hi, Im working on adding multilanguage to my project. When using a button to change language I get "invalid value 0 in parameter xxx". The zero...
1,028
Good morning Please i need an advise, I have a s5 135u cpu system , it is installed on printing machine. Nowadays its stop about 10 times in 8...
27
4,278
Hello, I have connected ethernet cable with my laptop and the s120 control unit. setup my laptop ip 169.254.11.1 and subnet mast 255.255.0.0 ...
20
5,605
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,864
