Problem with Stratix8000
Diego_Lopes
Jun 2012
Olinda
Hi all. I'm facing a problem with Stratix8000, it seems to work well when suddenly the devices does not communicates between themselves, if I restart the Stratix8000 it comes back to normal function and all the devices can communicate properly. The curious thing is that all LEDs of Startrix8000 indicates that nothing wrong is happening. If someone can help me i'll be grateful.
You have a dedicated Power Supply for the switch?. Or at least a Power Supply that does not leave the panel and does not power any field I/O?
Are you using IGMP snooping? If you do not have a IP address setup in the switch then IGMP is off. If there is more than 1 switch the switch with the lowest IP address will be your querier.
Check and make sure your firmware is recent also.
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
35
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
46
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
58
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
496
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
68
