problem with vijeo citect not write variable
antwan_jacoup
May 2010
alexandria
I use Vijeo citect with Modicon M340 with Ethernet ( Modbus/TCP )
Citect read all variable ( Bool - Int ) but didnot need to write any variable . can any one help me
i found answer and solve this problem :
Modify the parameter [LAN]AllowLegacyConnection.
[LAN]SecureLogin=0
After created user and after login you usually have the right to write and modify registers.
I was using EM6400 energy meters with Vijeo Citect scada in Modbus RTU network & mapping as following successfully. NAME- KW_SMS_1 TYPE- REAL...
2,508
i have a problem with vijeo citect 7.2 alar, server stopped and not shown the alarms when i a in run time mode . what i can doooo to restart alarm...
1,982
Hello, I have configure some digital alarm and thats alarm i have to Log in SQL using cicode but when i am trying to this this it cant work...
2,553
Hi All, The Scada system is not displaying the alarms but displaying / controlling all other signals. The basic alarm server configuration /...
3,642
Hello, I am responsible for implementation of Vijeo Citect 7.4 SCADA in my company. I want to connect to Beckhoff PLCs by using Twincat OPC...
2,007
