Problem Working with citect and Excel
RodriC
Jul 2005
La Paz
Hi everybody; ive read all about citect and excel i found, but i still have a problem i would apreciate if you could help me:
I have to see the value from some tags, for example 2) in excel and record its value constantly, ive worked with ddeformu.xls, but i only managed to watch the variables in "real time" but i can ´t save its value, please help!!!!
Ive been triing with ciode and writing macros, any solutioon would vçbe a good one, help please.
I'm just doing a project using Citect now and would be happy to help.
Your question is a bit vague. For starters, have you managed to write anything at all to the database?
You need to DevOpen the database in Cicode and then use SQL functions to access it. First, however, you need to define a Device that points to the table in the database and also to enable the ODBC server on you computer to point to the database.
Let me know if you have written at all to the database and where exactly you are up to and I'll try and help
Cheers
JT
I have got a strange issue during developing the project where the FT View application is interacting with PLC via the OPC UA server. So, there is...
2,019
I am trying to configure vfd(MM3) through cb15 to cp342-5 and having a cpu 314IFM. I have set all the parameters of drive and I think it is...
22
4,050
Having a problem with a windows XP pro SP2 networking problem thats got me stumped. The network goes from a touchscreen which transmits a small...
5,584
Hello, I have making in an Excel-sheet a DDE-link Topic between RSLinx Classic and a PLC5/25 processor. When the value in the cel of the...
2,051
I have an E-1061 terminal from Mitsubishi. I can use it to talk to a PC and even my PLC, but not through a hub. Anyone ever encounter this before...
1,822
