Problems with RS Emulate 500
dcooper33
Jun 2011
Rogers, AR
717
Ok,
Now, thanks to OkiePC and dara, I can post this screen shot:
I've been using RS Emulate for a while with no troubles, until I began using it with Archie's AdvancedHMI. I was using the DF1comm driver on the HMI, and channel 0 on the emulator to communicate through a virtual pair of serial ports. Everything worked fine on the PLC and HMI, it did everything I wanted it to. It's actually a lot of fun to play with. The problem came when I stopped running the HMI, made a change to a button, then started it again.
Then I get "no comms" messages and noticed that the emulator had frozen up. When I tried to restart the software is when I got the above message.
I was able to remove/re-install the emulator software and it worked again for awhile. Then after bricking again, I still get the error msg even after a re-install. I tried to make sure I removed all traces of emulate from the hard drive before re-installing, but to no avail.
I made sure that I wasn't running RSLinx while running the HMI software, so there would be no driver conflict, although I was only running the EMU driver in RSlinx, so I'm not sure it would have interfered with virtual serial comms in any case.
Any one have any idea what might have gone wrong, or how I can get Emulate working again?
Thanks,
Dustin
I don´t know, but like your screenshots shows, the problem is with RSlinx Clasic and not with RSEmulate , maybe you can re-intalling again and prove it.
it seems that in your pc .dll file is missing so either reinstall rslinx or restore your pc to your previous day when it happen
Yes, but what is strange is that if I go to that filepath that .dll file is still there.
I'll try re-installing linx today and see what happens.
Thanks for the replies.
Cheers,
Dustin
23753 - RSEmulate 500 Cannot Load EMU500X.DLL
Access Level: Everyone
Date Created: 01/17/2003 12:00 AM
Last Updated: 10/25/2010 12:26 PM
How do I resolve the RSEmulate 500 cannot load EMU500X.DLL error message?
Problem
The following error message is generated after RSEmulate 500 fails to load EMU500X.DLL.
The user should press OK, not Cancel, to close the window.
Cause
After RSEmulate generated an application error, the Microsoft C++ debugger was started when the user pressed Cancel to close Application Error rather than OK.
Solution
Shut down RSLinx or reboot the computer to release the file.
Problem
Cause
Solution
D'oh!
Rebooting the PC worked like a charm. Thanks jk
Dear bro, I'm using RsLogix Emulate 5000 ver 20.01 and FactoryTalk View Studio 7.0 with Windows 7 64-bit Pro. And I got some display errors like...
4,806
I am having trouble with 5000 emulate .when i try and create a controller i get error msg that sez "failed to install rslogix emulate 5ooo in...
19,633
Just wondering if anyone has encountered the following problem with RSEmulate 5 version 5.00.05 (originally version 5.00.03): When I try to start...
6,178
We are having issues with our viewpoint server randomly crashing and only loading the error page if anything at all. It lives on 3 servers all of...
60
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
236
