Problems with S5 CPU 928B
linadr
May 2017
La Habana
Hi experts:
I have an S5 PLC with CPU 928B. A week ago had an error, it was in STOP state with the red led flashing quickly. I did it an overall reset an rest and go to RUN state. Then when T start to transfer the program blocks corresponding to OB, DB, SB and DX returns to the STOP state.
Can you helpme with that problem????
If I realized an overall reset and transferred the program block. How can I fix an ADF error???
Thank you for assisting me
"ADF" LED Addressing error; the user program has accessed an address in the
process image for which there is no module inserted in the I/Os.
i think u have a defected module as manual say ( i think analog i/o will be the problem if you have one )
yes, I have 4 analogic input and 4 output, And recently I had to change an input module because it had some components burned.
Do you think the new module has problems with the address ???
i don't know the manual say u have done incorrect address so u have to check all modules
but check the analog module u change maybe it got a wrong addressing but i will check how u can do it
Hello all. I am trying to create a project to download to my CPU312 (312-1AE13-0AB0) and I can't get it to add this device. The device and article...
21
1,386
hallo i am having a problem the wago module and the cpu are connected with each other and the adresses are oke. but my tia portal keeps giving me...
4,690
I have developed quite a few functions and fb’s for Simenes 1200’s but now I’m making a bigger application and I ordered an ET200s but I have to...
3,172
Hi, I have a new Siemens 400H-CPU. On the rack there is a power module, a CPU and an ethernet card. I need to download the hardware...
1,995
i have this CPU, and i can't communicate with it. there seems to be something wrong with the unit, because the LED configuration is something i've...
3,179
