Produced/Consumed tags with PLC/5 over DH+
TConnolly
Apr 2005
Salt Lake City
6,152
I need to exchange some info with an enhanced PLC/5. The PLC/5 is linked via DH+ to a 1756 DHRIO module in slot 1 of a 4 slot 1756 chassis. The chassis also has a ENBT module in slot 0 to form a bridge to the plant network.
I've added some ethernet IO and drive to the system so I put a second ENBT module in slot 2 and in slot 4 is a L55 CLX processor, rev 16 (max rev for L55 processor).
The CLX is processing the ethernet IO and needs to exchange four 16 bit words with the PLC/5.
Is it possible to use produced/consumed tags over DH+ through the DHRIO module or am I going to have to message the info? I'm not seeing how to configure it over DH+.
Msg is all I could ever get.
The PLC5 would have to handle implicate messaging right? As far as I know that isn't an option
there is an example over on mrplc that used a plc5 to read/ write to a CLX using tag names.
The produced consumed tags over cnet is just function of cnet doing tag passing isn't it? Similar to global data in the SLC or Plc5 right.
That is what I was afraid of.
Also saw on technote 39806 that it is not possible to schedule produced/consumed tags across a bridge.
So I'm stuck with messaging. Its not a big deal. I spent more time futzing with it that it would have taken to program the MSG.
Thanks.
Not really. But I can see the comparison. The RSNetWorx software is where the configuration is setup. It's much more flexible and allows a lot more data. But it is scheduled data, not just data being passed by the token roation.
OG
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
191
Hi I have been knocking my head against the wall trying to figure out why these two plcs won't talk with Produced and Consumed Tags data. The...
493
Hello all. I have a 1769-L16 that I inserted a 1769-L35E into. I was expecting it to create module defined tags automatically in my controller...
1,825
Hi, Can a tag configured as a Produced or Consumed tag be read or written to with Explicit Messaging? Context: we are retrofitting an AV system...
2,288
Ok, I've setup comms to PLC's that are behind a NAT switch before, but I have not had a PLC behind one NAT switch communicate with a second PLC...
3,461
