Profibus FMS: is there a master on it or not
sinanissa
May 2004
Al-Balqa, Fuhais
17
I have an old system for tracking our product: pipes. and i am working for this company for five months.
this system contains a Profibus FMS network between 6 Siemens PLCs (300 and 400) and 2 Control Cards on special systems for testing pipes, and One PC with Aplicom Card which supports the profibus FMS hardware connection.
Now we need to connect another PC to the network, where both PCs will get data from the PLCs and these two Control Cards. Before doing it, can i do such a thing, i mean, can i make two masters on the same network? please, if any body know a website that can explain more about Profibus FMS, include it in your reply.
thank you all.
hello sinanissa;
There is a lot of documentation on FMS available on Siemens' support website (www.support.automation.siemens.com), such as this introduction:
http://support.automation.siemens.com/WW/view/en/1652762
If you search for the SiemensFMS comm. processor numbers in the Search box, you should find some good manuals, Faqs.... to helps you out.
Hope this helps,
Daniel Chartier
Thank you daniel for the link.
I have another question. On the same network that I mentioned before, if i just take off one of the connectors from the PC side, just like this, pulling it out and let it there, shall the network continue running without any problems?
I tried to search this in the link that Daniel give it to me, but i did not find. The problem that we will run a two systems at the same time: one new and the other is old. after the new system succeeded, we will remove the old system. So the connector will be without any termination or will not be connected to any device. Is this healthy for the network or not? If it is not, what shall i do?
I know may be it seams that i can just put the new PC in the place of old system and return every thing to previous situation but with the new system. But the administration is pushing me to relocate the position of the PC.
thank you all for reading and replying.
Hi all, I'm doing with profibus fms. I have a plc s7 315-2dp, a cp 343-5 (support for profibus fms) and WECS3000 (a product of wartsila...
2,467
Hi, I'm doing a project involve Siemens S7-300 and WECS (Wärtsilä Engine Control Unit) The WECS has profibus FMS port and can communicate with...
1,963
Hi everyone! We are using Moeller PS416 PLC with PC HMI based on Wonderware Intouch 7.0 on Windows NT Workstation 4.0. The protocol that we are...
2,431
Can anybody tell me how to link that networks optimally? We must to develope new SCADA with Modbus Plus interface (it's necessary because many...
2,322
Hello all u S7 PLC Gurus.. I have some questions for you about Simatic 7 FMS CP cards.. First I wonder whats the diffrence between FMS cards...
3,728
