Profibus module for plc2
Jul 2007
Kiruna
600
Hi all,
I have a customer that wants to add 8 new drives to a plc2 control system. The drives are vacon with profibus interface.
Can someone please suggest the best module as dp master? Prosoft?
Which model of PLC-2 controller are they using ? Are they running any A-B remote I/O with a RIO scanner ?
My first suggestion would be a 1771 style Profibus-DP scanner module. SST made one, though I don't know if it's available anywhere but the aftermarket now.
I don't know for sure if those would work with a PLC-2, though. In general, block-transfer devices will work with any controller that performs block transfers, but the SST-PFB-PLC5 was probably only tested with PLC-5 controllers.
Personally, if I had the money to purchase 8 new drives with Profibus cards and integrate them into an existing system, I'd be asking for enough money to migrate the PLC2 to a Control Logix or Compact Logix system. I'd be afraid that in the course of trying to graft a new Profibus master onto the PLC2 something that is currently working would fail. Furthermore, even if components of the PLC2 die a natural death, it will get blamed on you. I can already hear the comments. "It was working fine until Morphius got that bright idea to add those drives".
We've a 555-1106 with one remote base and three other PB devices. This base has a 505-6870 RBC, and three modules / IO cards. I am trying to add a...
1,586
Dear Sir, I have a healthy profibus communication between SIEMENS PLC S7 400 and Allen Bradley drive PF700 using 20-comm-p profibus dp module...
2,822
i want connect remote profibus slave i/o to s7-300 plc. which module should i use? plz help.
1,680
Hi, guys, how’s going? We have one production line that uses AB logix5000 as main PLC and FANUC robot, SIEMENS 840Dpl as slaves. The slaves...
1,643
I have an S7 1212 with CM1242-5 Profibus module configured in TIA V13 to connect to an S7 315 2DP Profibus master. The configuration is set up for...
2,599
