Profibus PA
MrQ
Feb 2005
236
Hello,
We are about to deliver a system with Profibus PA for sensors, actuators and drives connected to the PLC.
Is there any kind of "instrument" that can be used to connect on the Profibus PA bus to simulate sensors or actuators for functional testing??
Do you want to simulate a single device in an operational situation or the entire bus for testing in simulation mode?
What kind of Profibus DP-PA gateway do u use (Siemens or P&F)?
The gateway is P&F.
I would like to simulate one device at a time.
You could use a PROFIBUS DP simulation program like PICS (see http://www.woodhead.com/products/brad/bradcommunications/simulation/). This program can simulate any kind of PROFIBUS DP slave. Since you use P&F every PA device is transparent and will be configured like a PROFIBUS DP device.
I'm not sure if this is what you are looking for since this kind of programs are usually used to simulate the entire I/O that is connected to the PLC. For one device this would be overkill. A complete setup for this would set you back around EUR10.000,00.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
200
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
99
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
117
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
329
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
329
