profibus question
DeHulk
Mar 2003
74
a project from 3 s7 PLC's connected with profibus but only one is connected with ethernet
Should it be possible to monitor the program from the other two PLC's?
Are all 3 PLCs connected to each other? When you say monitor the program, do you mean the program in a PLC other than the one your computer is connected to?
OK. Let me get this straight.
You have 3 Siemens S7 PLC's. The 3 stations are contained in the same
project. All 3 stations are linked via profibus. One station has an ethernet module. You want to use routing to talk to any of the 3 PLC's through the ethernet connection. Am I right?
How about listing what CPU's and Ethernet modules you have.
i think it's like that ! i shall check for more information about the hardware tomorrow at work
PLC 1:
1 ps407 10A
3 CPU414-2DP
x2 DP
x1 MPI/DP
4 CP433-1(1)
5 CP433-1(2)
PLC2:
1 PS307 3a
2 CPU 315 -2DP
x2 DP
DI
DO
PLC3:
1 PS307 2a
2 CPU315 -2DP
x2 DP
4 CP 342_5
5 siwarex U-1
i made a screencapture of the network but my pc don't recognize the disket here :-(
hope you can help me out !
Hello,
I think when you put all the three plc's in one project in the manager and configure your network (through Netpro) it must be possible to program all three stations from one location. I did it myself once via MPI. And this worked good. Maybe you should also connect via de MPI/DP adapter instead of the ethernet with the first plc, but that cannot be a big issue, because the other 2 plc's are also not through ethernet connected.
To program over ethernet I think you need Simatic NET for Ethernet.
The standard PG connections that comes with STEP7 is not enough.
But please do check up on this, as this from the back of my head only.
I heard that Siemens is about to release a "lite" version for Simatic NET Ethernet with just a few connections allowed (this is cleverly timed with the release of the CPU 317 2DP/IT (again the CPU type is from the back of my head)). You could check up on this as the "standard" version of Simatic NET for Ethernet is rather pricey.
some additional info
the PC from wich a can monitor one of the tree PLC's from this projects is also used to monitor other project
I am trying to get my S7-315, a TP1200 Comfort Panel, and another profibus device to all communicate. I am using S7 V5.5 for the PLC and TIA for...
3,317
Hey all. I don't like to do this, but we've got like a huge thing going on here, and they'd like for me to get it over with as soon as possible...
5,459
Hello All, I tried searching for this information first, but didn't find anything that helped me out. I'm 99% sure I know the answer, but would...
1,550
I am building a new panel with a GE Versamax PLC and 6 ABB freqdrives, among other things. The powers that be have decided to control all 6 drives...
5,869
Could someone tell How the bits are mapped in a S7 224 For Profibus communcations. I have several that communcate with TI 505, In the s7 software...
2,112
