Profibus read in
jimmy_r
May 2003
Hasselt
I've got a challenge for all Siemens programmers out there!
I need to somehow read in from a Profibus network on a S7 to view all the participants. Unlike Interbus, profibus doesn't have an option to read in from a current setup.
Is there a special program to do this? With VB or C++, is there a way I can connect to the S7 and write my own program to read in a profibus network?
Thanks in advance,
Jim
What's the challange ?
You just want to get a list of all the DP-nodes that exist on your network? or detailed information of the vendors and ID's of the devices.
To do this from your PLC directly simply use SFC 13, this function call allows you to read out the diagnostic data of DP slaves.
You just need to write a kinda function around this SFC 13 to aim your target.
If you search long enough on the Siemens website you could find an example of such a function also.
Kind Regards/Westvloamse complimenten
Using the Step7 programming software, create a new project. No hardware configured. Open the hardware config and then hit the UPLOAD icon and when it asks what project, select the new on. Once it is uploaded, save it and hit the 3rd icon from the left "Online". You should be able to look at all of the modules. On line and off line.
Hi, Can anyone recommend a good profibus encoder that can read the speed of a shaft? I'll be using it on a S7-300. Thanks
1,784
Hello, New to the forum here, and to the controls industry. I am trying to do the following: Read and Write to a 5204-DFNT-PDPMV1 ProLinx...
1,893
Can read an analog value via Profibus? I'm using a plc s7 300 and a sensor SITRANS Probe LR.
1,720
Dear All Can any one help me the detail doccumentation of SFC 14 and SFC 15 data read and write from the DP slave?.Also any good manual on...
2,121
Hello. I am new to S7 programming and need some help. I hope I´m clear enough... I need to read some data(current,power,...) from a SENTRON...
5,967
