profibus
Very limited summary:
PROFIBUS DP [FONT=&quot](Decentralized Peripherals)[/FONT]
  • Mainly used for remote I/O, drives, sensors, actuators, communication,…
  • Electrical: RS485 (or fiber)
  • Transmission speed: 9.6kbps …. 12 Mbps
  • Cable length: 100 … 1200 meter, depending on transmission speed
  • No or very limited spur lines allowed
PROFIBUS PA [FONT=&quot](Process Automation) [/FONT]
  • Mainly used for process automation (instrument networks)
  • Electrical: MBP (signal and power on the same wire)
  • Transmission speed: 31.25 kbit/s.
  • Protocol: same as PROFIBUS DP, but you can use “profile GSD “files to make it manufacturer
  • Independent (with some limitations).
  • Cable length: 0…1900 meter, depending on used cable, current consumption, length of spur lines, EX zone, available power, ….
The is lots of information on the site www.profibus.com
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
198
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
94
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
115
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
328
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
327
