Proficy ME OS requirements
DHoward
Jul 2012
South Carolina
25
Proficy ME OS specs support Win7, 8, & 10. I currently have an installation running on Windows 2003 server. (Not by choice). Does anyone know if ME will run on 2016 server?
I have no actual experience running PME under a non-supported OS.
Try installing. It may abort the install if it detects a non-supported OS. If it installs, it should run, but since it isn't specifically listed in the release notes, don't expect any help from support if you have issues.
What could possibly go wrong?
I asked Ge about running on windows server and they said no. But wasn't till after trying it on 2003 and it crashed the server. They said You can however build a Virtual windows or such inside the Server and run it that way. Still in the planning on doing it that way to run our web based Runtime. I don't know about the newest Proficy 9.5 but know it was up to 9 they said it did not support server Platform. Regards
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
61
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
114
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
106
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
76
I am trying to download a program with usb to serial cable in rx3i IC695CPE305 while logic and configuration is equal but when i start downloading...
51
