program access denied
rejoe.koshy
Dec 2011
kolkata
195
hi guys,
I have a problem in viewing the logic after I have uploaded it from a controller.None of the routines are accessible & displays a message which says "access protected from user".I cant even save the program to my PC.I am using a micrlogix 1200 PLC & rs logix 500 programming software.
Pls help me to find a way out.
The image of the screen that appears is attached.
Can you tell me exactly where in the program do I put in the password?
Can i save the program to my PC without the password?If yes, how?
in this particular case, it's not really a "password" that you can enter ...
this is an example of the "OEM Lock" protection scheme ... (Original Equipment Manufacturer) ... you need an exact copy of the RSS project file – and you need to put it on your programming computer in the directory that RSLogix500 is using to store its projects ...
basic idea:
in this protection scheme, the RSS file acts something like a "key" which will unlock the controller and let you see the logic inside it ... RSLogix500 looks for the file/key – and if it isn't present, then you'll get the message that you're seeing ...
you can read more about this subject by going to the "Protection" tab in a temporary dummy file – and read the Help information about the "Deny Future Access" bit – S:1/14 ...
short story:
you need a copy of the original MATCHING project file (RSS extension) in order to open this one up ...
I'm not sure about the answer to that question ... try clicking File/Save and see ... (personally I doubt that you can - but I'll have to wait till I get to the lab to try it out) ...
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
95
Hello, all, total noob here hoping for a little guidance. I bought a new piece of printing equipment that has a Mitsubishi PLC and this Data...
189
Hello All I hope you are well and safe. I have a problem that I could use your appreciated input for: SW: SIMATIC MANAGER v5.5 SP3 HW1...
1,232
Hello All I would like to have your expert advice, If I can access the Hidden or Locked Program in the PLC Program by any chance. The PLC is AB...
5,510
EDIT: Reworded after post #3. Original wording posted as a reply (#4) for reference I have a Siemens IPC427D running WinLC RTX F, and every...
3,910
