Programming a GE Fanuc 9030
What do you program a 9030 with?
  • Logic Master LM90
    Votes: 14 63.6%
  • VersaPro
    Votes: 7 31.8%
  • Cimplicity
    Votes: 6 27.3%
  • Proficy
    Votes: 3 13.6%
  • Hand Held Programming Unit
    Votes: 1 4.5%
  • Total voters
    22
I've used the top three, mainly used VersaPro and Cimplicity (Machine Edition) because they were bought for the project. If I had to do a competitive bid, I would use LogicMaster and save the money.
LM90 fro older versions of CPU Versapro for the newer.
Versapro good for multiple windows where many subsections are availbleto view in diagnostics .
LM90 sturdy program but I can find it a bit cumbersome.
Given choice would opt for Versapro.
I have used and taught the use of all three, LogicMaster 90, VersaPro and Proficy ME (or Cimplicity ME).
It was always a "pain" in one way or another to change and they all have there pros and cons. There really is no "real good" reason not to stay current with any Software that you use a lot, in my opinion.
Yes, once in awhile a bug will be introduced but they are always fixed. Once in awhile we may lose a 'feature' or two, usually temporarily.
But.....
If you really get to know the new software and use it as intended, you will 'always' be more productive with it. If this is not the case, the developer will go out of business.
I can not recall any software package that I have ever used extensivly that would be an exception to this.
The key is to learn it and use it as intended and NOT try to force it to "work like it used to".
I used LM90, Cimplicity Control and Versa Pro.
Versa pro because I have an XP machine. Windows packages seem to be much easier when you don't use it enough to remember all the keyboard shortcuts.
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,918
Hey Guys, I have plenty of experience with AB plcs . What is a good starting point to learn about fanuc robot programming. How to get started? Is...
2,720
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,131
Hello Everyone, I would like to get some advice from seniors!! Currently, I involve in writing PLC logic and Robot programs (ABB rapid...
3,912
Hi Guys, I'm looking for someone who might still have software that can open a program from and old 90-30 PLC. We have just taken on a new...
34
23,352
