Programming using PLC Control Builder (AC 800M)
ch33lin
Nov 2009
singapore
The speed of the fan motor is determined by the room temp
When temp > 70%, speed of fan is at 100%(65535)
When temp < 50%, speed of fan is at 50% (32768)
Run button will start fan via digital input to the vsd, and send analog signal to vsd.
Stop button will set digital input and analogue input to zero.
A low_temp indication turns on when temp<10%
How do i program this using PLC Control Builder (AC 800M)?
Help is so much appreciated!
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
169
I am in the process of buying a new laptop and can't decide between a zbook g4 and a thinkpad. I mostly use virtual machines and would like the...
29
8,848
Hi Everyone! For those who used to program or familiar with PLC and HMI programming that follows the standard for packaging equipment...
4,558
Hi all, We have some small installations out in the field controlled by DL06 PLC's and Easyview HMI. It is not possible/allowed to wire them to...
3,246
Hi Everybody, Can anyone tell me how a PID control programming can be achieved by PLC using versa pro.I know PLCs now a days can be used for...
11,229
