Protool help text
Werner
Apr 2005
IJsselstein
336
In protool you can add a help text to various objects. When I add an help text to an input field the user can read this text when he presses the help text on the keyboard. (The keyboard opens when you select the input field)
It is also possible to add helpt text to buttons. But I cannot find how the user can read this help text? (I use protool pro 6.0 and the display is an MP370 15" touch, without seperate keyboards or mouse so just touch) Does anybody have a clou how the user can find/read these help texts?
I do not know how to do that either, but this is a way accomplish the same thing. Put an invisible button on top of the 'real' buttons. Add a 'Help' button on the screen. When the 'Help' button is pushed and activated, the invisible buttons are active. Now when the 'real' button is touched, the invisible button is really touched so then you display your help message. When the 'Help' button is inactive, then the 'real' buttons work when touched.
i finished a new project by protool v.6 sp3 on win xp , i have S5 TTY Programming Cable when i connect to op 15 display transfer ready but when...
1,285
This is a different problem but on the same machine as my other post. Basically there is an alarm message showing up on the TP270 HMI, and I am...
6,626
Hello I have a problem when I try to convert a protool project in wincc flexible. I receive the next error: 14:44:44.78 General Error ...
2,292
Hi, I need to switch two MP270B Protool projects over to WinCC Flexible. I'm going to do this late tonight and i...
4,273
Hello i'm a protool beginer and i have to make a school work. the work consist in make the game BATAK, the program in plc is done, and i have to...
2,090
