Protool runtime
Amr Hassan
May 2005
340
Hi
to my knowledge, protool can be used as scada software instead of wincc for small applications , but when when open the protool an new project is started by selecting the used op and none of these is the the use on pc
how to run the project on normal pc?
You need Protool Pro to configure PC applications. The regular Protool only covers the panels.
Protool Pro generates a runtime file that must be run with a Protool RT license.
You must purchase a RT license with sufficient tags (128-512-2048 tags are available).
edit: You will also need some communication hardware.
For MPI or Profibus I recommend the CP5611.
For Ethernet a regular ethernet port on the PC is enough.
WinCC Flexible
ProTool is being replaced with WinCC Flexible. Flexible can do anything that Protool can do plus. Development is a little slow but runtime is great.
Hi all, I am using Protool 6.0 with Step 7 V5.3 and Simatic S7 300. The problem is that in Runtime mode when I push switch button to ON position...
2,705
I am posting for the first time. I have problem starting the Protool Loader. Whenever I start the Protool Pro RT Loader the following error...
2,482
Can anyone help with with an issue I have been having for about 6 months? I have protool runtime running on a sinumerik 840di machine operating a...
2,538
Hello, I have the following configuration: Siemens PanelPC 577 CP5611 WinLC V4.0 Protool Runtime ET200S So far all the...
4,939
I am attempting to inmplement a runtime meter in one of our Siemens PLCs. I am using SFC3 to start/stop the runtime meter, and SFC4 to read the...
3,654
