Protool script problem
Borte
Feb 2004
Norway
238
Hello guys!
I have a problem figuring out how to use the VB script functions on a Siemens TP270 to dynamically change the size of a object on the screen. I'm aware that I can change the position but I also want to change the width and height.
In regular VB I can write it like this: object.Width = value but how do I transfer this to protool?
Cheers
Borte
Hi folks, I was playing a bit with protool scripting today. And have a problem, protool doesn't allow me to have a script of more then 20...
2,285
Hi I'm writing some software in Protool that involves a lot of tags. I've written a script that executes upon 'screen generation' along the...
6,932
Hi! i have write some VBScript that check a plc variable (for example m100.0). When m100.0 raise to 1, the script read up to 50 tags and write...
4,896
I have to generate report in Protool on PC via Trigger from S7 PLC Bit.Like we can generate report by using function Print Report in TAG...
4,032
Does anyone know where I can download the Simatic ProTool software? Thanks.
1,533
