ProWORX Vs Concept
Max Modoc
Feb 2013
Gridley, California
New and just starting out, I am working on a project at work with a Schneider Electric Momentum 171CCC96020. I pick up a copy of Concept, But I was told ProWORX would be easyer to work with. Any thoughts, thanks for your help
You will need Proworx32. I hope you like ladder logic!
The 171CCC96020 doesn't support the IEC programming in Concept. There is a trial of Proworx32 that does up to 25 networks of logic, but I am not sure about other limitations.
All I can say is check out Schneider Electrics web site...
Welcome to the forum.
Proworx NXT was nice software - but it was 16 bit software written for Win95.
Proworx32 is buggy and has a annoying case of attention deficit disorder.
If you don't want to use Concept then look at a third part product, PLC Workshop for Modicon from FasTrak SoftWorks. Not a lot of frills but all the functionality you need for 984LL (doesn't support Modicon Quantum). It has a very clean UI. You can download a demo from their website.
I've used all three.
I have just started a project using a Concept PLC and Magelis HMI. The Vijeo Designer software for the HMI is pretty straight forward but the...
6,031
Hi Everyone, is there a way, using Proworx NXT to export the Ladder to a text file ? I can easily export the comments, no problem. I need...
3,757
I haven't tried this yet, but has anyone tried swapping the program databases between Concept and Proworx? I know this would only be possible...
2,310
Will Proworx 1.11 work with Momemtm Micro 110 CPU? I know Pro Lite will, but that is version 1.0 Also, I haven't dealt with Siemens before...
3,164
I have a zip file of a program that I'm told was created in Proworx NxT. Would the comments be stored in it if I could find the software or...
578
