Pto Jog
aryautomation
Nov 2006
texas
34
hI GUYS,
I AM USING ML1100 TO RUN TWO SEPPER MOTORS. ON EACH STEPPER MOTOR WHEN THE INPUT GOES HIGH, IT SHOULD TURN FOR FEW STEPS IN ONE DIRECTION AND THEN CHANGE DIRECTION FOR THE REST OF THE STEPS. I AM THINKING TO USE THE JOG FEATURE, BUT I DO NOT KNOW HOW TO PROGRAM THE JOG FUNCTION.
ANY HELP WILL BE GREATLY APPRECIATED.
First for be able to jog, you must disable EN bit of PTO by open the rung of the PTO instruction.
Then, enter a jog frequency in PTO:0.JF (if PTO:0 is used). If you enter a value less than zero or more than 20 000 plc will give you a fault. If you leave 0, no mouvement will occur when a jog will be requested.
Next step is to select what kind of jog you need, JP (jog pulse) increment one pulse at time or JC (jog continuous) for jog at selected speed s long signal is egual 1.
Anytime you can monitor you jog status thru JCS and JPS read bit in the PTO function file
Wish I help a bit
Good luck
Check out the ML1100 Instruction Set Reference Manual (1763-RM001A-EN-P). Let me know if you need a link to this.
Refer to the detailed information on the PTO (pulse train output) instruction. I think it is under the chapter dealing with high speed outputs.
This should give you everthing you need...!!!
I currently use a Jog Continuous at 5000hz successfully. My application requires a two speed blended jog now. I need to start the jog at a...
2,587
am planning to build a small machine which have 2 Axis (linear motion and rotary motion) am confused about using closed loop stepper motors (PTO...
1,016
Hi Everyone am controlling a stepper motor with 1215 plc, when using motion control(V6/7) you don't have any option of using HSC as feedback is...
913
Micrologix 1400 PTO function file. I set ADI to “1”. Right clicked ADP, selected “set independent accel/decel value location”, and entered L9:0...
791
Hi, I can't seem to find a thread on this, so I'm starting one. I want to use 2 PTO outputs off a BXB 1400 Micrologix series C. BUT... I need...
1,678
