PTO versus analog reference.
pimpim32
Mar 2003
123
Hi everybody.
I was wondering what are the advantages of PTO control of a drive over analog control.
Up till now we are using only 0-10V as speed reference for the drive, however I noticed that some micrologixes come equipped with PTO , also some drives with pulse train input so I might use them.
How long can last an FET output? I know they are saying a lifetime, but what's a lifetime? for 1Khz reference and let's say 20 hrs/day, 360 day/year 10 years we have about 260 bilion cycles.
Any thoughts?
Marian
From what I found up till now a solid state output have
"higher life time then mechanical relay" :)
20x more, 50x more , some 100000 hours or 11.4 years.
Still waiting for AB guys with their answer on ML1200 high speed output.
also that PowerFlex700 can get input up to 420Hz and F7 Yaskawa up to 32KHz ( quite a difference).
So nobody has an opinion about pulse train agains analog speed reference?( not for positioning,just feed material into a loop)
One reason is some Mlogix PLC's have a PTO on the main unit but if you want Analog you might have to buy an expansion module. With the PTO, you could save that cost.
For the moment I do not intend to use PTO.
However as Tackdriver pointed out ML1200 BXB for example has one output suitable for PTO/PWM, so no need to buy an extra analog card.
Other consideration could be noise issues. I guess PTO is better than analog about noise, but other people may say otherwise.
For me except life expectancy of the FET output i do not see another reason why I would not use PTO, but again is good to know before some pitfalls of a method before finding out on your own skin.
am planning to build a small machine which have 2 Axis (linear motion and rotary motion) am confused about using closed loop stepper motors (PTO...
1,017
Hi Everyone am controlling a stepper motor with 1215 plc, when using motion control(V6/7) you don't have any option of using HSC as feedback is...
916
Micrologix 1400 PTO function file. I set ADI to “1”. Right clicked ADP, selected “set independent accel/decel value location”, and entered L9:0...
793
Hi, I can't seem to find a thread on this, so I'm starting one. I want to use 2 PTO outputs off a BXB 1400 Micrologix series C. BUT... I need...
1,687
Hi, Does anybody know if it is possible to run Yaskawa's DriveWizard software on a PC, to monitor and configure V1000 VFDs that are connected to...
2,072
