Pulse out or PWM
ilhem
Dec 2004
Constantine
74
HI; i am new in SCL500 , i have this configuration :
CPU SCL 5/03 , output module 1746-0b32,
I want produce pulse out or PWM from OB32 module , is there any simple program for this ?
If you are refering to pulse outputs used for making things flash, or blink, i use this piece of code to provide 1 Second On/Off and 0.5 Second On/Off pulsing
T4:100.TT (Timer is Timing)is 1 Sec On/Off
T4:98.TT (Timer is Timing)is 0.5 Sec On/Off
Thanks for reply, i want use a PLC output for using frequence to voltage converter for driven a power supply (0-24V 1.5A)
I don't think you can do this the way you propose unless you have some custom V/F converter I'm not familiar with.
The fastest response you can get from an OB32 is dependent on the version. the sereis D has relatively fast hardware, producing turn on delays of 0.1 msec and turn off delays of 1.0 msec. The OB32E has on and off delays of 1 and 2 msec respectively. So the D series card could get you a max symetric pulse rate of 500 Hz. The E variant would be limited to 250 Hz for a symetric pulse.
Even given this I don't believe you could get the PLC to respond that fast to control the outputs. I'm thiking even 100 Hz would be pretty ambitious.
If you could do a long cycle time proportioned output (slow speed PWM) you may have a chance. But to get any kind of resolution you would need a time period on the order of 1-2 seconds.
Keith
So i have OB32 version C , i think is not a good solution for generated a pulse out by this way , do you have a other solution?
Use an ML 1200 or 1500 using the PWM or PTO instruction, if necessary connect that with your SLC 5/03 so it can tell it what you want it to do.
Help me. I want to create a PLC program Pulse width modulation (PWM) with Simatic PLC s7300. using SFB49. but I have never made it. is there who...
2,576
Hi, I am trying to write a ladder logic using PWM and INI instructions to actuate a fast switching solenoid valve at a range of frequencies. I...
11,271
How will generated a 2 pulses outputs in the s7 1200 plc.... 2 pulse outputs of s7 1200 PTO or PWM are there.... i think PTO is digital output &...
7,034
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
164
Hi All, I'd like to know can we use DTR instruction to get a week pulse ? Could anyone please help me to understand that one ? I've managed to...
187
