Pulse Width Micrologix 1100
Ce.O
Sep 2018
MEXICO
19
Hi, folks.
I want to know, whether it is possible to read the pulse width or some instruction, I have not found something abou that, with micrologix 1100. I have reading about High speed counters, but I think it's only used to count pulses and not to read the width. If someone know something, please tell me or if it impossible do that with PLC's, may be it is impossible.
Thanks, I'm working with RSlogix 500
A HSC like 1734 or 1794 normally can be more than one mode: counter, pwm, period/rate, rate measurement
If you use period /rate, the frequency is your pulse width:
There is no canned feature to do that, that I am aware of. You could build your own pretty easilly, but at typical MicroLogix scan rates it would only be accurate at very low frequencies.
I am monitoring two BMXDDO3202K digital outputs for their behaviour, they are each for opening and closing, and so the on time affects how far the...
290
Hey guys, I have a client that has a v-notch chlorinator that doesn't run off a 4-20mA loop, it instead has two discrete inputs that drive the...
1,886
Help me. I want to create a PLC program Pulse width modulation (PWM) with Simatic PLC s7300. using SFB49. but I have never made it. is there who...
2,576
Hi, I am trying to write a ladder logic using PWM and INI instructions to actuate a fast switching solenoid valve at a range of frequencies. I...
11,272
how can I change an analog output just with the program not using a digital input? also I need to ramp up and ramp down the analog output please...
4,185
