Pump Speed based on tank level
Beau79AU
Feb 2018
NSW
Has anyone setup pump speed based on a tank level? I have a situation where i have a 2 part grout system where the pumping ratio needs to be 1:1 between the 2 tanks. The grout slurry can be abrasive and builds up so I was thinking of using ultrasonic level sensors for the tank levels instead of using flow meters, but im just not sure if it will be possible to change the pump speeds. Both products have a different viscosity so will not pump at the same rate.
Regards
Beau
I'm not sure I follow. Why do you need to change the speed of the pumps? I see you need to maintain a constant blend, but are you controlling the speeds to an overall flow target or just trying to not under/overflow the tanks?
Typically with blending, having a flowmeter on each feedstock works the best, regardless of what you're trying to control to.
I am at a loss... I have a pasteurizing system that i need to control product temperature with the speed of the product pump. I currently have a...
2,610
I have a chemical mixing system which is controlled by a Controllogix system and using Factory Talk SE for display and HMI. I have 3 pumps which...
2,180
Hello everyone, first time poster here. Hopefully I won't sound as stupid as I think I am. :o: I am an old programmer, but have always been...
1,565
Hi, I am working over controllogix platform, i need to get the pump average % speed of whole day, kindly help me out here, regards, Danish
1,863
AB CompactLogix L32E Processor RSLogix 5000 Version 20 Tank 100 is filled with liquid, a level transmitter LT-120 is installed on Tank 100 and...
6,852
