harryting
A good general practice is to treat the HMI command and command to the device as two separate items. There are many reasons for this; communication glitch, allowing for multiple HMI, reboot of HMI or PLC, etc... In NO WAY you would want the HMI to issue the stop command even though I assume the Limitorque would not act on it once it reach it's destination. Treat the HMI command as a start/stop to a separate sequence to open/close the valve.
Also, if there's any chance of something gets stuck the valve, you would want valve fault logic where it stop the action and let "maintenance" open/close action taking over where you have to maintain the open/close to jog the valve to either end.
BCS, nothing. Keep in mind the HMI is basically doing a one shot and doesn't check the PLC status again. IE. HMI is not constantly syncing the database. To make PLC code works with various HMI I used to make this type of of logic
--| HMI Set 1 | -----------(Latch command)-----
--| Command |------------(Unlatch HMI Set)----
This also take care of slow communication
