I have made some changes in a process. The process is devided over 3 PLC's. I cannot deploy it during production time so to test my changes I wanted to make 3 VM's with WinLC running in them and 1 VM for devepment with Simatic and Wonderware Archestra IDE. The CPU's are running, they can ping each other and I can see every CPU from the development VM. So far no problem. All 3 PLC's were communicating with Put and Get functions. So in Netpro I made the necessary connections with the right ID's that the Put and Get functions are using. In Netpro the connections become green when I check this status online. The Put and Get functions give me status 25, and the error bit is true, no data is received or send.
Put and Get are maybe PLC functions that don't work with WinLC ?
I then tried TCON and Open Communication over ethernet, but no succes so far. Anyone has an idea what I could try ?
Thanks in advance,
Kind regards,
Combo
Thanks in advance,
Kind regards,
Combo
