PV+1500 question
angi
Jan 2010
us
361
Hi
there are some question about PV+:
1. I import a Motor sample from libaray, what I want is go to another screen when I press the sample. when I open animation function, the "touch" tab was grayed out. how to make this happen?
2. when I double click the motor sample, the property window was shown up, but it was a "PolyLine" property window, why?
thanks
Hi
thanks
I don't have a "touch" option available at all. I have never seen that with Factory Talk View Studio
The options I have under animation are;
Visibility...
Colour...
Fill...
Horizontal Position...
etc
thanks
The motor symbol is created out of multiple Polylines...
The easiest way to do this in factorytalk is to have a goto display button on top of the motor or whatever picture you have and then make this button invisible.
Mark
Mark
Agreed Mark, thats what we do on our PV+ projects for tooltips for level instruments as well. Just click on the status bubble and a small box pops up with the tag information.
Just a goto button in transparency over the top.
Same for Pump and Valve Auto/Manual Control.
Mark
But don't use the animation --> visibility setting to make it invisible, as you won't be able to access it at runtime.
The button should be invisible because of the colour it is, or its "back style" is set to transparent :)
"Touch" is available in SE but not ME
Thanks Guys
I got it fixed, just set as "Transparent" for the Goto Button, it should work.
Is it possible to configure the PV logout / login functions so that they're triggered from the PLC? I want to log who starts what on my system...
1,724
Hello All, I am doing a PLC5 to CLX conversion and asking if someone can point me in the right direction. Let me prefix this by saying that my...
1,583
OK I have a PLC, configured with 10 words of alarm bits B9:10/0 - B9:19/15. They already have a description, which is pretty much what I want to...
2,961
hi i have problem with connect PV 1500 to Backup SLC5/05 Via serial Port my system as follow : primary Rack 1747-1553 , 1747-BSN...
1,903
I have a PV1500+ and Logix5561 talking to each other via Ethernet. I'm trying to find decent examples to how to set up communications between the...
3,033
