PV+1500 update
angi
Jan 2010
us
361
Hi Guys
I just got a problem after the the program of PV+1500 was updated:
I added some buttons function to the program, everthing runs good except the login password changed for one of the display, but I did not change anything for security.
What's wrong about this?
Hi Oki
I just uploaded form the PV+, changed it and loaded back. the FactoryTalk software never show me version issue. Is there anything wrong if the version is different? what do I need to do about the version issue?
There may have been issues if you had to change versions from 3.2 to a newer one.
Since you were able to upload the .mer and restore and edit it, can we assume you are running 5.0 or 5.1?
Another possibility might be that the security password was changed at runtime and was overwritten by your download. Do the security settings in the offline file match what is now in the machine?
Oky
1. There is an account ID: A6FCDD19_A76A, how come the ID display like this?
2. there is not function to change the PW at runtime in this application.
3. Yes, I am runing version 5.0.
I had a similar experience when I tried to edit an application that was created by the OEM. I believe it had to do with whether or not you restore the local factory talk directory when you first restore the application. Answering yes would have fouled up my machine, but answering no caused the security settings to become randomized.
My solution was to manually edit the fields, save the file, make a new runtime and transfer it.
EDIT: If you have techconnect access see answer ID 45605
Hello All, I am doing a PLC5 to CLX conversion and asking if someone can point me in the right direction. Let me prefix this by saying that my...
1,583
Is it possible to configure the PV logout / login functions so that they're triggered from the PLC? I want to log who starts what on my system...
1,725
OK I have a PLC, configured with 10 words of alarm bits B9:10/0 - B9:19/15. They already have a description, which is pretty much what I want to...
2,961
hi i have problem with connect PV 1500 to Backup SLC5/05 Via serial Port my system as follow : primary Rack 1747-1553 , 1747-BSN...
1,903
I have a PV1500+ and Logix5561 talking to each other via Ethernet. I'm trying to find decent examples to how to set up communications between the...
3,034
