PV 300 Configuration
Sparky2
Jul 2003
I need help- I want to use a PV 300 with a OMROM CPM2A. I have used Panelbuilder to do a project with a PV and Micrologix, but I do not know if it is possible to configure the PV to use the tag addresses of the DM type from the OMRON- Has anyone done this before? Is it possible or needed to use the OMRON as a node?
Does the Omron speak Modbus? Cause that's the only non-AB serial port protocol available in PanelViews, and I'm not even sure if the PV300 can do Modbus. Another possibility might be DeviceNet if you can get a DeviceNet interface for the PV300 and for that model Omron.
In general, PanelViews don't have a large choice of non-AB communications protocols.
Thank You
Thak you Steve-as you can probably tell-I am a novice about protocols. I am trying to make the impossible, possible.
Profibus is an option in some Panelviews as well, but neither is an option for the PV300 family.
From the AB website:
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
65
I have Windows 7 Pro and am trying to configure ABs 9300-USBS USB to RS232 adapter. I have done it in Windows XP but am having problems with Win 7...
2,295
Hi, I got two questios: There are two slave devices(SEL-787) from which I should read data via MODBUS RTU. I checked SEL-787 manual and it says...
5,569
Is there a way to configure these starters without the faceplate? The customer did not buy any faceplates and the manual refers to different...
2,154
Hi , I am looking for the solution, how to configure I/O of E300 . For example , Input 1 trigger Output 1, Input 2 trigger Output 2. In...
1,297
