PV+7 Modbus/TCP and Ethernet/IP
mcfarlde
Mar 2010
Alberta
Hello, Can a PV+7 do both Modbus/TCP via KepServer to some devices at the same time it is doing Ethernet/IP to a PLC?
Yes, as long as it's the "Performance" model, not the "Standard" model.
The "Standard"has the performance limits that used to be part of the "Compact" models, that support only one driver and one data source.
The "Standard" units support one native FactoryTalk Linx Enterprise driver, or one KepServer driver, but not both at the same time.
I am having trouble establishing communication between a PanelView Plus 7 Standard and a SLC5/05. A little background: This was a working setup...
830
Hi there everyone! Long time lurker, first time poster. I am doing an SLC-5/03 to CompactLogix migration and am having an issue with a barcode...
1,059
Hi all, I rarely work with this software, and I either can't remember what to do, or have never actually done it. I have a PV 10" HMI...
1,071
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
91
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
68
