PV+ 700 "Version Incompatibility Error"
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,808
After finally grasping how ME works and getting my changes tested on my remote PC, I downloaded the app to the PV+ out on the floor.
When I went down to see the results, there was an on screen error stating that the new application could not be run due to a "Version Incompatibility Error"
Does that mean I need to update firmware in the unit?
I went ahead and restarted the original app, so we are running. Tomorrow I will try to get a better understanding of what this means.
I am running RSViewStudio v 4.0 I am unsure how to determine the firmware revision in the PV+.
Thanks in advance!
Paul
With RSView Studio v4.0, you can compile the MER file (runtime) to a 3.x version. When you create the MER file, just choose the correct type in the SAVE AS TYPE box. This is probably the version you need for the FW in the PV+.
from the PV+ configuration menu
Select Terminal settings
select RSView Me Station
Eventhough you can upgrade the firmware in the PV via a download, I think most PV+ do not contain enough free ram to allow this to happen. Upgrades need to be performed via compact flash
Ian
from the config menu go to system information and about RSview ME station
This will tell you the firmware rev. you can either rev up the firmware or save as an earlier when making your .mer file..
!!Must type faster!!
D
I have never had to upgrade with compct flash..i have always done mine on line..
Ian
evertime I try to upgrade, I always get an "insufficient memory" error even after deleting all apps within the PV+
Ian
strange....i only ran out of memory once, and i had 3 or 4 .mers in memory..and they all had about 15-20 large JPEGS in them..plus the usual screens and alarms..(the Jpegs were a special treat for the maintinance guys if they started the machine at a certain time every morning!! one would flash up for 10 seconds then dissapear..once per day for 15-20 days..then repeat..unless i happened to be in the plant then i would replace them..(thats why there was 3 or 4 versions in the memory)..it took some time on my part to do it but the guys enjoyed it..and if i even needed anything..i just had to ask..
d
Thanks for the excellent responses. You guys have saved me a bunch of reading, and I was unsure where to start. My partner is here today and says that when FUP-ing, he usually gets the insufficient RAM error, then deletes the projuect(s) in the PV+, then it usually works over ENET.
To me it might be a little risky to load firmware over ethernet, so I think I will use the compact flash method for that step.
Having upgraded a whole lot of PV+ terminals, I've become very conservative. I back up all the *.MERs, the Kepware configurations, and the loaded fonts.
Then I delete them all, and reboot.
THEN I do the upgrade, using a dependable-as-a-mule 512MB SanDisk CF card.
The autorun utility and batch files are my friends.
I have run into a situation where I am now on "borrowed time". Our company has finally used it's last PV600 "spare" and now we are going to have...
4,607
Hi, Just started working on a new project. The machine has an Allen-Bradley MicroLogix 1500 and a Panelview Plus 700 touch. The original PV...
23
12,897
Hello Everyone, I'm terrible when it comes to communication and its protocols. Keyence has provided me with the BT-A700 Wireless Scanner which is...
48
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
124
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
72
