PV, Panelview 634 Read Timeout Node 2 error
Dec 2005
Texas
Hello,
I've done a search on the forums and found out some information about the 634 timeout error that I'm getting on the Panelview.
Our Panelview talks to a Logix5555 controller and a "634 Read Timeout Node 2" error keeps popping up. (Node 2 is our controller)
I've done the following:
1. I've made sure all cable connections are good
2. I've checked all points on the Panelview to see if it's available on the controller and checked all the data types to make sure they match.
3. Increased NUT from 5ms to 10ms and increased Interscan Delay from 160ms to 640ms.
4. Checked to see if PanelView UMAX is greater than Panelview Node number (UMAX=10, Panelview Node=5)
Any other ideas?
Appreciate any comments.
I am assuming your PV is on Controlnet.
We had one install with many PVs on various C-Net legs. Almost all PVs had intermittent timeout errors until we done two things:
1 - Increase the NUT, which you have done. RSNetworx for C-NET can show you network utilization and you can determine if 10ms is enough
2 - Used the proper AB Controlnet crimping tool. As it turned out our amatuer crimping job without the tool caused most of the issues. A properly installed connector should not be abled to be pulled off.
Ian
Hi all, A customer has an existing Panelview 600 that has apparently operated for some time without fault but has recently started locking out...
2,404
I replaced an existing PanelView 300 with a new one. It is the same style as the old one and I took the file directly from the old one and put it...
1,827
I have a PanelView 550 and am communicating with CompactLogix conroller. I'm wanting to use the status tag for the screen number in ordre to make...
2,302
i have 2 backups: *.PVC and *.pvd file types thanks in advance for any help
95
I'm at a loss here and hoping someone else has seen this: Background: We've got two identical machines on our floor (we'll call them machine A &...
65
