PV PB32 download problem
RickParrot
Nov 2015
Iowa
68
I am using a NC13 cable to download a new PV program, and RS Linx sees the PV, but when I go to download, it says, "Error 1022 Target is not an Operator Terminal". For the Download I am using the PB32 File Transfer Type DF1 Point to Point--RSLinx AB_DF1-1.
When I try a different File Transfer Type, I get prompted to disable the Printer port. How can I see if the printer port is disabled if I can't go online?o_O
Cant do the download. Anyone help?
Can you get to the configuration screen? If so check it there.
You can also use the port used to communicate with the PLC to upload/download the program.
I had this pop up today on a PanelBuilder, PanelView 550. I can not find it in the PB messages any where. I pressed any key like it said. Every...
2,662
On PB32, PV 600 I want to add a screen for a analog tempurature trend. How does the Graphic Indicators-linear set up work? Where do I add the tag...
1,211
Hello, I am hoping for some help with setting up a .mer. I will try and give as much detail as possible, thanks. I am trying to convert a .pba...
2,335
hi guys im having an issues converting a panelview 600 to panelview plus 600 ? I have done 2 hmi program conversion on factorytalk studio but...
1,599
Hi Friends ! I'm having a little challenge here, I'm almost done in my conversion project from panelBuilder to Factory Talk. I really need a...
1,592
