PV+ Screen Saver
junior
Jan 2006
Seattle
271
I'm looking to change the AB graphic on a PV+ 1000 screen saver. When I search around I find info on the topic, but the answers are linked to the AB knowledgebase, but when I click on the link this particular topic is locked to people who have the Techconnect subscription. Can anybody post the how to?
I've also found the instructions on how to change a PV+ CE, but following them didn't work for me on a standard PV+.
Jr.
You can create a .bat called "autorun.bat" with the following:
Code:
pause
Basically what you will need is the autorun and a new .bmp that is named "oem.bmp". Then you put the autorun and the oem.bmp on a flash card an pop it in the panelview. It will copy the file on. Then you just reboot and you are set.
This is what I tried, but I couldn't get it to work, so I assumed that this was only for PanelView+ CE and not the standard PanelView+. Basically I followed instructions in the attached document.
What I described was how we change our screensavers on PanelView Plus terminals (not CE).
Probably done it 200 times or better. If you want, PM me your e-mail and I will send you the autorun.bat.
Just make sure that your image is a bitmap and it is named "oem.bmp"
When you plug in the flash card, a window will open and the file will be copied. You just close the window and the next time that the terminal is rebooted, it you should see your screen saver.
Any good idea how to dim the display on a panelview plus performance serie b, at idel. Screen saver is not supported yet I have don it in global...
2,242
There is a screen saver function for the Panel view 5310. It utilises a AB logo splash. I would like a custom image to be the splash for the...
1,281
Would love to just have the scrensaver come up, full screen company logo, and thats it. i attempted to make the logo 320x240 and it did fill the...
2,786
Hi. I have a used PanelView Plus 400 that already has a custom screen saver on it and I'm looking to change the screen saver I was reading the...
3,429
I bought a used PV+ 1250 off of Ebay and it has some company's logo on it. I want to revert back to the plan old A/B Screen Saver but I cant find...
1,179
