PV1000 to CompactLogix
plc-friend
May 2005
26
Hi we have a DF1 tochscreen PV1000 that we want to communicate with a L31 CompactLogix processor.
The problem is when we define a tag in panelbuilder, it says that it is an invalid tag for the terminal protocol.
we`re just given the name of the tag that we`re using on RSLogix 5000.
my question is :how to enter tags for this kind of processor?
any suggestion would be apreciated.
I did one of these a while back. If I remember correct you have very limited data types when using the DF1 protocol. I think you will need to use the PLC/SLC mapping to make this work.
In standard PanelViews only the Ethernet IP and ControlNet PanelViews can reference ControlLogix tags without mapping the data.
Here is a link to a KB document that details what data types are legal in a PanelView.
http://rockwellautomation.custhelp.com/cgi-bin/rockwellautomation.cfg/php/enduser/std_adp.php?p_faqid=18034&p_created=953838298&p_sid=iy7Zjgni&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTE1NSZwX3Byb2RzPTAmcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PVBhbmVsVmlldw**&p_li=&p_topview=1
One little note in addition...the article references ControlLogix processors, this also applies to the CompactLogix.
That's it, just wanted to make sure that was clear.
OG
I have a mer or apa file for Pv1000 (2711p-rdt10c) and i need convert this files for Pv5000 (2715P-T15CD-K). Are exist a conversion tool for this...
864
Hi, im looking to migrate a 2711-K10C10 to a 2711P-T12W21 Panelview Plus 7 Standard. I migrate the PV1000 application .pba file in FactoryTalk...
1,985
Hi there everyone! Long time lurker, first time poster. I am doing an SLC-5/03 to CompactLogix migration and am having an issue with a barcode...
1,056
Hi, I'm investigating the feasibility of communication between a old PV standard display and a logix L5X controller via the controller serial...
1,468
Hi all, Anyone manage to get this smorgasbord of hardware to cooperate with each other? PLC - Micrologix 1500 1764-28BXBAA CH1 config - DF1 Full...
1,499
