PV1400 Communication error
RasPLC01
Sep 2011
AUS
56
Hi Guys
I have been experiencing a communication issue with PV1400 ( 2711-K14C1) Showing a error message "65 No PLC communication"
The system is as follows
PV1400 is communicating with 1747-ASB Through RIO , and RIO Communicating with 1747-SN installed in SLC 5/03 Chassis.
System was working. I have done a small modification on ladder (LAD 4 RUNG 102-118) .After one hour since i download the modified program , HMI Start showing " NO PLC Communication .
indication on the SN module is flashing green , and ASB module showing RUN and steady green
We have check the cable continuity and baud rate , those are correct
Can you please suggest solution ?
SN module installed on slot1 on main chassis and ASB on slot 0 on a remote chassis
please PLC and HMI programs find below
https://dl.dropboxusercontent.com/u/57875618/programs.rar
Hi Guys I have been experiencing a communication issue with PV1400 ( 2711-K14C1) Showing a error message "65 No PLC communication" The system...
1,559
I have a dead panelView1400 (not 1400e) that is being replaced with a panelView+1500. I need a little help with the conversion. For the 1400...
2,196
Dear members please give me a solution for following error in AB panel View 1400 which is communicating with SLC 5/03 I have been trying to...
28
6,361
P
I use “Panel View e Transfer” to transfer file: XXX.pvc (the program file for Keypad )to the PV1400e terminal. The transfer did not succeed...
3,772
P
I need to find a library of bitmaps for the grain mill industry, to use with an AB pv1400
1,497
