I encounter a problem of 1400e panelview when switching screen commanded from PLC from a page to another. It take about 10-15 second to change the screen from one to another with PLC command control
The setting and communication protocol as below:
1) communication network: Remote I/O, baud rate: 230.4K
2) the addressing for tags are in I/O type for pushbutton and indicator display
It required long time to switch the screen commanded from PLC but if using goto screen button, it work well.
Our application use a lot switching screen from PLC.
The detail of the PV1400e as below:
Cat: 2711E-T10C6
Series: C
Revision: A
Firmware: 5.13
Cat: 2711E-T10C6
Series: C
Revision: A
Firmware: 5.13
