PV300 5/03 cable
ctw3
Dec 2007
Australia
25
Hi all,
sorry for asking a question which has probably been answered a lot in here, but I cant seem to find the right part number.
I have a PV300 and a 5/03 SLC, can I connect the PV to a channel with my PM02 and then connect my PC to the other channel with my standard CP3 cable?
I think I have got myself confused with channels and part number...
cheers
Charlie
Yes you can use the 1761-CBL-PM02 cable to connect your PV300 Micro to your SLC5/03's serial port. The SLC5/03 serial must be configured for DF1 protocol and match the baud rate of your PV. ( see PDF below for connection diagram)
The other port on the SLC5/03 is a DH485 ( RJ45) port only.If your computer/Laptop has a real serial port then you can use a 1761-NET-AIC with proper cable and the DH485 driver in RSLinx to connect. You can also use a 1747-PIC device ( older device also need real serial port) to connect to the DH485 port same DH485 driver.
Your best choice for this DH485 port is the 1747-UIC ( USB to DH485 converter)
Sweet, I knew there was a way to do it, for some reason I could olny find the 1747-PIC, not the 1747-UIC which is what I need.
thanks Mickey
cheers
I think I need some advice with something else, in relation to the above.
I have my 5/03, and my PV 300 2711-M3A18L which I now know what part I need (thanks to Mickey)
I also have another 5/03 which I would like to add a Panelview to. I dont have the Panelview yet, but I would like touch and color. I will look at purchasing once I work out what I can/ can't do with it all,
so here is the plan...
My 1st 5/03 and the PV300 are connected to my brewing outfit I have, controlling valves, water flow, a pump and a few thermocouples, works great.
I wish to add my second 5/03 to control general home duties, some lights, water pump on my rain water tank and anything else i can think of.
Due to switchboard space, and cable length, the second SLC can't be installed where the brewing one is, and I want the new color screen upstairs. We are not talking huge distances here.
I would like to access via my home LAN if I can. So can I get a 1761-NET-ENI and then join that to another comms device which my 5/03's will be attached. Or do I need to get a NET-ENI for each SLC.
ie, can I ethernet to a DH485 network, which has a 1761-NET-AIC and some 1761-AIC modules?
I am sorry for the long post, but I wanted to hopefully give as much info as I could.
cheers
Quick question.... Can I just add a null modem adapter to the 1747-CP3 cable that I use between my SLC 5/05 and my PC to connect my PV300...
2,579
Hello all, I've utilized many threads on this site and gleaned much information throughout the years. Now the time has come for me to finally...
1,790
Hey, I'm trying to upgrading some old PV300 Micro screens. I have communication on RSLinx but I can't get it to where I can get to the program...
2,909
The question is at the bottom ... 1st the buildup. I would like to change a prgm that is in a PV300 Micro which is configured by Allen Bradley...
27
8,071
I am using an Allen Bradley PanelView 300 Micro with Panelbuilder32 software. I am unsure on how to assign a screen to a function key? (F1, F2...
3,065
