PV550 2711-K5A9L1 problem to connect.
Oliver Micka
Oct 2015
Hlohovec
65
Good evening/day...
I have a PV550 ( 2711k5a9L1 - frn 4.11) and i have a several problems with connections between panel and PC ( pc have a com port )
I need download aplication from PC into the panelview.
This panel have a two RS232 connectors ( 1 used only for Printing and 2 is used for communication RS232/DH485 )
I have:
- RSLinx Classic ( i don't know a number of version but it is a newest version)
- RSLogix500 ( SLC 5/04 - 1747 L542 - os401 )
- Transmitter 1747-UIC ( USB / DH485 )
- I don´t have original cable 2711-NC13 ( i used classical cross serial cable RS232 )
- 1761-NET-AIC / 1747-AIC - this devices were not used yet..
1, COM port (rs232 - cross serial cable) --> HMI - No response..
2, COM port (rs232 - cross serial cable)--> 1747-UIC --> HMI - No response.
I don't know what next try
please can we help.? ?🔨
regards..
Your UIC should work. You need a staright thru cable ( that is what the 2711-NC13 is).
Baud rate at 19200 (UIC only supports this)RSLinx's node address must be different then PV.
Make sure you use the comm port the UIC was assigned. Check device manager.
See link
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CDgQFjAAahUKEwjV6cC8quvIAhVJ_mMKHT5fBcs&url=http%3A%2F%2Fliterature.rockwellautomation.com%2Fidc%2Fgroups%2Fliterature%2Fdocuments%2Fin%2F1747-in063_-en-p.pdf&usg=AFQjCNEs977tcxJnvTucX9FfjWROwmwdyQ
Yes i saw originally pinout cable 2711-NC13
http://i46.tinypic.com/155kjev.jpg
I mean it's a serial cross cable.. ( 2 and 3 position is crossed ) ((or am I wrong? ))
RS Linx i have a allright configured..
After connecting 1747-UIC in to my PC (RS link is configured for DH485 - UIC devices) i see only UIC adapter and that is all.. ( now is there my PC name, but before there was name 1747-UIC )
http://postimg.org/image/atfy1ku2p
many thanks.. regards
Hello! Communication setup of the PV550(2711-K5A8) under configuration mode looks like: DH+/node2/Br57.6 I use 1747-UIC interface, 2711-NC13...
2,112
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,229
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,676
We have an old machine that has been mothballed since early 2018 and management are looking at more work for it in 2022. The system runs on an SLC...
2,883
Trying to write a program for a PV550 (2711-T5A16L1, Ser. B, Rev. E, FRN 4.46) to test the touchscreen. I wrote a program with 16 pages and on...
1,696
