PV800 6 Position Selector Switch
willings
Oct 2016
Greymouth
Hi all
I am setting up a batch tank system, I have 1 pump which can pump to six different tanks(via pneumatic actuated valves). This is my first go with a HMI, usually I would use a multiple position switch. Is it possible to make a six position selector switch with a HMI? I am using a AB Panel-View 800, has anyone done this before?
Any help would be appreciated.
Take a look into the Multi State Push Button and the List Selector Object, both will do what you request. Operating the List Selector requires aditional Key Objects that will also require space on the screen. The Multi State Pushbutton will basicly cycle through all states and start over at the first state when clicked.
Add an integer tag to your plc and link it to one of the objects.
OK I see, I tried these ones, but I thought that they should be linked to multiple Boolean tags. So I need to link to a integer tag. Got It.
As the title says, I'm using CCW with a PV800 (and Micro850). I've made a scheduler in which a user can choose a month, day (1-31), hour (0-23)...
538
Scenario: This is for a system that has a PV800 user interface (connected to a Micro850 PLC) programmed with CCW. There are various control...
561
Hi All I have a Panelview 800 HMI hooked up to a Micrologix 1400 controller. I have communication and have the screen set up with some...
938
I have a USB port RFID Scanner I am using for badging users into certain access levels in an HMI. I know that I could create a 'login' button that...
618
Hi Friends, I am trying to connect MLX1400 over RS232 serial communication with PV800. I am not sure where I am going wrong, the PV800 doesn't...
962
