PV900 Communications
WildBill49
Oct 2005
York, ME
We are trying to communicate directly to the PV900 with an RS232 comm port, using our laptop. We are using RSLinx and Panel Builder 32. We have a lot of different cables and we also have a PIC module. We need help configuring everything.
You have a DH485 protocol PV. You will need to use the 1747-PIC/AIC+ driver in RSLinx. You have to have a real serial port to use this driver.
Cable needed is a straight thru.
If you don't have a real serial port on your laptop then a 1747-UIC ( USB to DH485 converter) would be your best bet.
Thanks Mickey. When you say "a true serial port", do you mean a 9-pin "D" connector on the back of my laptop? Or can I use a USB to 9-pin "D" cable?
Hi All, I have two PV900 I would like to swap, ones screen is dead/dying. from Ser-F Rev C(dying screen) >to> Ser-D Rev S obviously the PVA cant...
2,720
Hello! I am working on setting up a PanelView900 to work with a machine using a SLC5/03. The PV900 only has Ethernet and DH485 ports, so I assume...
20
7,351
Hey All. I am having an issue with an old PV900 Standard. The part number is 2711-T9C9. The first issue is that on powerup the screen is sittting...
2,610
Iam having a problem tracking down a fault on a machine. The problem is with a separator controlled by a SLC500 (1747 L542B 5/04), this has a...
2,517
The problem started with an error 208 in my PV900 after a program change and download to my slc 5/04. The logic had worked for over 2 years...
2,771
