PVP Remote Display Print
jedft
Jul 2004
145
I want to set up a Panelview Plus to automatically print a data log screen every day at midnight. Obviously, I need to use the global connection "Remote Display Print" However, the help file says I have to disable the screen saver to use this global connection. I presume if I tried to print a screen when the screen saver is active that it will print a blank screen. However, the customer does not like the prospect of his screen burning out faster because I have to turn off the saver. So, I thought maybe at 11:59 I will use the "Remote Display Number" to change the current screen to the log screen. I am hoping this would disable the screen saver (as if someone had touched it) and then at 12:00 I could send the print command. Anyone know if this will work? As usual I don't have equipment in-house to test this and the jobsite is hours away. Thanks!
Hi all, i am running a PVP1000. The details are as follows: CAT: 2711p-rp6 Firmware: 5.00.04.55 (CPR9) I bought this version of PVP logic...
2,131
Hello all, My experience is largely siemens based, so I figured I would consult some local AB guys for this question. We have a machine that...
1,189
Hello, I made a small change to my FTV ME file (added an ack-all button) and re-downloaded to my PVP. Since then, when the application starts up...
1,023
Hello everyone, I'm seeing Japanese characters with a 90° rotation on a new PVP+7 screen. I post here hoping someone has encountered this issue...
759
I've got a relatively simple standard system with an issue that is frustrating us. Upon powering up the system as a whole, sometimes the Ethernet...
630
